6 Fiscal Report
The cash register system must be able to generate an X and Z reports per Point of Sale.
By definition, the Z report is a daily summary of the registrations in the cash register and X report is a summary of registrations in the cash register since the last Z report.
It is a requirement to produce the Z report but not necessary to have it printed for each Cash Register, and you must describe how to get it printed on demand. Producing the Z report may therefore be connected to a change of business (system) date in general and both of these report are required to print on demand.
The X and Z reports should be printed/displayed on any Cash Register. One should be able to run/print the Z report on scheduled task and/or manually.
It is important that running/printing of both the X and Z reports is written into the Electronic Journal.
The X and Z report are generated from Administration, Reports, Reports module.
For X and Z Report Structure, see X and Z Report Structure in the Appendix section.
Figure 6-1 Report Printing Function
