4 Contract
The Contract configuration page allows you to setup and manage a contract template.
Contract Category
The Contract category enables you to assign/group similar contracts. You can either use the pre-defined category when setting up a contract or create them during contract creation.
Figure 4-1 Contract Category
This figure list the Contract Category and the option to create a Contract Category.
Creating a Contract Category
  1. From the Administration menu, select Enterprise, and then select Contract.
  2. On the Contract Category tab, select Create Category.
  3. Navigate to the Add Contract Category page.
  4. Enter the Category Name.
  5. Click Save.
Modifying Contract Category
  1. On the Contract Category tab, locate the record and click Edit.
  2. Navigate to the Edit Contract Category page and update the category name.
  3. Click Update to save changes.
Deleting a Contract Category
To delete a category, locate the record and click Delete.
Contract Template
The Contract Template enables you to create different types of contracts, for example, general terms and conditions. If the contract is not ready for use or no longer required for the future, you can slide the status button to deactivate the contract or delete the contract if it is not in use.
Figure 4-2 Contract Template
This figure shows the Contract Template and list the template created.
Figure 4-3 Contract Template Edit
This figure shows the edit page of Contract Template.
Figure 4-4 Contract Template New Category
This figure shows the new Contract Template, Create New Category option.
Creating a Template
  1. From the Administration menu, select Enterprise, and then select Contract Template.
  2. On the Contract Template tab, click Create New.
  3. Navigate to the Add Contract Template page.
  4. Enter the following information and click Save.
    • Template Name: Enter the name of the template.
    • Category: Select the category code.
    • Contract Details: Enter a contract description.
    • Terms and Conditions: Slide to set this as mandatory. Once enabled, the guest must acknowledge the contract at check-in before proceeding to the next step.
    • Text box: Enter a Terms and Conditions description.
    • Remark: Enable if you need to show the remark in Check-In, Check-In Wizard, or Contract page.
    • Signature: Move the slider to set this as mandatory. Once enabled, the guest must sign the contract page at check-in before proceeding to the next step.
Editing a Template
  1. On the Contract Template tab, locate the template record and click Edit.
  2. Navigate to the Edit Contract Template page.
  3. Enter the relevant information and click Save.
Deleting a Template
To delete a Contract Template tab, locate the template record and click Delete.
Creating New Category in Contract Template
  1. On the Contract Template tab, Category field, click Create New Category.
  2. Enter the Category name in the Create New Category prompt and click Save.
