3 System Parameter
This section describes the parameters available to the QCI Sync module and is accessible through the Administration module, System Setup, Parameter, General group. You must configure these parameters before running the QCI Sync Interface.
Table 3-1 PAR Group General
PAR Name | PAR Value | Description |
QCI Offline DB Terminate |
24 |
Disallow the QCI Office DB to run if it is older than x hours. Specify in the parameter value. The default value is 24 hours. |
QCI Offline DB Warning |
12 |
Define when to prompt a warning message when the QCI Offline DB is older than x hour. The default value is 12 hours. |
Pax BCard Track2 Length |
16 |
The length of the |
QCI Sync Active Warning |
12 |
Prompt a warning message when the QCI Offline DB is running more than x hours. The default value is 12 hours. |
