6 Parameters
This section describes the Parameters available to the Safety Drill module, and they are accessible from System Setup, Parameters, Administration.
Table 6-1 PAR_Group: Safety
PAR Name PAR Value Description
Advance Safety Drill
0 or 1
0 - Standard Safety Drill Handling.
1 - Advance Safety Drill Handling.
Course Code for Boat Commander
XXX
Qualifying course for Boat Commander. (XXX=COU_CODE)
Allow Multiple Safety Number Assignment
0 or 1
0 - Do Not Allow Multiple Safety Number Assignment.
1 - Allow
Allow to use special In Port Manning handling
0 or 1
0 - Disallow
1 - Allow
Auto Set Ashore Denial During Drill Scheduling
Specifies the duration before a Drill starts that going ashore is denied. Duration in minutes.
Display Valid Courses On Muster List Assignment
Displays the list of important courses on the Muster List Assignment window. PAR_VALUE should contain COU_CODE separated by commas. For example: 331,321.
Operational Position that Receive Message
The crew of certain operational position to receive a warning message in Active Muster List when there is expected crew in the muster list.
Table 6-2 PAR_Group: Promo
SMTP Server IP Address
Enter the Local Exchange server IP Address
SMTP Server IP Address.
SMTP Server IP Port
Default SMTP IP Port is 25.
SMTP Server Require Login Authentication
0 – No or
1 - Yes
SMTP Server Require Login Authentication.
SMTP User Name
<userName>
Only valid when SMTP Server Requires Login Authentication is = 1.
SMTP User Password (Encrypted)
<userPassword>
SMTP User Password.
Sender Name
<senderName>
Sender Name.
Sender Email
<emailAddress>
Sender Email.
