Preface
The Track It program manages prohibited and restricted items such as camping gear, hazardous items, and alcohol from being taken on-board by passengers, visitors or crews. The function includes, but is not limited to Quick Collect, Quick Check-Out and Quick Return. These functions are designed to handle collection/return of restricted items, either by batch or individually.
Audience
This document is intended for application specialists and end-users of Oracle Hospitality Cruise Shipboard Property Management System (SPMS).
Customer Support
To contact Oracle Customer Support, access the Customer Support Portal at the following URL:
Product version and program/module name
Functional and technical description of the problem (include business impact)
Detailed step-by-step instructions to re-create
Exact error message received and any associated log files
Screen shots of each step you take
Documentation
Oracle Hospitality product documentation is available on the Oracle Help Center at http://docs.oracle.com/en/industries/hospitality/cruise.html.
Revision History
Table -1 Revision History
| Date | Description of Change |
September 2021 |
July 2022 |
Made minor grammatical changes. |
October 2022 |
Updated the document with correct format. |
December 2023 |
Updated new customer portal. |
