Preface
This document provides an explanation and description of each of the exposed functions in the Oracle Hospitality Cruise Shipboard Property Management System (SPMS) Web Service.
Audience
This document is intended for:
Third-party vendors who wish to integrate with SPMS.
This document should be used as a technical reference for external parties to develop applications which requires interfacing to SPMS.
Customer Support
To contact Oracle Customer Support, access the Customer Support Portal at the following URL:
Product version and program/module name
Functional and technical description of the problem (include business impact)
Detailed step-by-step instructions to re-create
Exact error message received
Screenshots of each step you take
Documentation
Oracle Hospitality product documentation is available on the Oracle Help Center at http://docs.oracle.com/en/industries/hospitality/cruise.html.
Revision History
Table -1 Revision History
| Version | Date | Description of Change |
20.2 |
September 2021 |
Initial publication. |
20.2.2 |
May 2022 |
Increased psNotes string from 50 to 200 characters in table ExcBooking and ExcBookingPackage. |
20.2.2 |
July 2022 |
Made minor grammatical changes. Updated two parameter fields to PurchasePackage function |
20.2.2 |
December 2023 |
Updated new customer portal. Updated PostingTotal Class for parameter gsCallNoDialed to String Type. |
