3 Web Methods
FidelioSPMSWSJsonGet
This function supports JSON get and JSONP get and does not support JSON post.
Input Parameters
Table 3-1 FidelioSPMSWSJsonGet Input Parameters
| Parameter | Type | Description | Required |
psFunction |
String |
Function to call. |
Yes |
psSessionID |
String |
Session ID. |
Yes |
psParam |
Array of String |
The field value will depend on the Function. Please refer to function detail for each available parameters. |
Optional |
The following section is the descriptions of the parameters.
psFunction
The ‘psFunction’ is the function name to be called.
psSessionID
The SessionID is a unique ID returned by SPMS WebService after a successful login function. This field is required in all function calls except login function.
The session has a timeout of 60 minutes from the last function call and value is configurable in the web.config file.
<add key="Idle Timeout" value="60"/>
When a function is called and if it returns below error, you must reverify by performing another function call. If failed, then re-login and retry.
Const SESSIONEXPIRY = "Session Expired"
Const INVALIDSESSIONID = "Invalid Session ID or Session Expiry"When you call a function and it returns below error, you must change the password and retry.
Const PLEASECHANGEPASSWORD = "Please change your password first"
poParam
The field value depends on the Function called. Please refer to the function details for each available parameters.
Return Values
Return the Class value below. The variable bSuccess is used to determine if the function call is successful or fail. If fail, sErrMsg becomes populated with the error message. All other fields will depend on the function call.
Public Class CResponseJson
Public bSuccess As Boolean
Public sErrMsg As String
Public sTables As String
Public nTotalPage As Integer
Public sPackageInfo As String
Public sCrewInvoice As String
Public sObj As String
End Class
oDataSet, oPassenger, oGuestInfo, oGuest and oAdvanceLoyalty will be serialized to sTables.
oPackageInfo will be serialized to sPackageInfo.
oCrewInvoice will be serialized to sCrewInvoice.
oObj will be serialized to sObj and sTables.
If oDataSet, oPassenger, oGu0estInfo, oGuest and oAdvanceLoyalty is ‘Nothing’, then this is for backward compatibility.
Sample JSONP
The requirement is that you must pass in the callback and format=json parameter.
GET /OHCWebServices/OHCWebServices.asmx/FidelioSPMSWSJsonGet?callback="Testing"&psFunction='WSFunction'&psSessionID='SessionID'&psParam=['GetCabin','05002']&format=json HTTP/1.0
Host: localhost
Or
http://localhost/OHCWebServices/OHCWebServices.asmx/FidelioSPMSWSJsonGet?callback="Testing"&psFunction='WSFunction'&psSessionID='SessionID'&psParam=['GetCabin','05002']&format=json Below are the sample responses that return two tables, and the text in red represents the second table.
Note: The Testing() is a JSONP response.
Testing(
"bSuccess":true,
"sErrMsg":"",
"sTables":"{
"Table1": {
"CAB_ID": "05002 ",
"CAB_DECK": "D05 ",
"DECK_DESC": "DECK 05",
"CAB_DESIGN": "P",
"CAB_TYPE": "CD4 ",
"TYPE_DESC": "CD4 - O/C Porthole (D4, D5, D6)",
"CAB_STATION": "B ",
"MST_NAME": "ASSEMBLY STATION B",
"CAB_MODDATE": "2011-10-27T10:26:43"
"Table2": [
"TYP_ART": "D00 ",
"TYP_COMMENT": "SEAT 1"
"TYP_ART": "D02 ",
"TYP_COMMENT": "DECK 02"
"TYP_ART": "D03 ",
"TYP_COMMENT": "DECK 03"
"TYP_ART": "D04 ",
"TYP_COMMENT": "DECK 04"
"TYP_ART": "D05 ",
"TYP_COMMENT": "DECK 05"
"TYP_ART": "D06 ",
"TYP_COMMENT": "DECK 06"
"TYP_ART": "D07 ",
"TYP_COMMENT": "DECK 07"
"TYP_ART": "D08 ",
"TYP_COMMENT": "DECK 08"
"TYP_ART": "D09 ",
"TYP_COMMENT": "DECK 09"
"TYP_ART": "D10 ",
"TYP_COMMENT": "DECK 10"
"TYP_ART": "D11 ",
"TYP_COMMENT": "DECK 11"
"TYP_ART": "D12 ",
"TYP_COMMENT": "DECK 12"
"TYP_ART": "D88 ",
"TYP_COMMENT": "PAX TEMP CABIN"
"TYP_ART": "D99 ",
"TYP_COMMENT": "CREW TEMP CABIN"
Sample JSON
The requirement is you must pass in the format=json parameter
GET /OHCWebServices/OHCWebServices.asmx/FidelioSPMSWSJsonGet?psFunction='WSFunction'&psSessionID='SessionID'&psParam=['GetCabin','05002']&format=json HTTP/1.0
Host: localhost
Or
http://localhost/OHCWebServices/OHCWebServices.asmx/FidelioSPMSWSJsonGet?psFunction='WSFunction'&psSessionID='SessionID'&psParam=['GetCabin','05002']&format=json
Below are the sample response that returns two tables, and the text in red represents the second table.
"bSuccess":true,
"sErrMsg":"",
"sTables":"{"Table1": {
"CAB_ID": "05002 ",
"CAB_DECK": "D05 ",
"CAB_DESIGN": "P",
"CAB_TYPE": "CD4 ",
"Table2": [
"TYP_ART": "D00 ",
"TYP_ART": "D02 ",
"TYP_ART": "D03 ",
"TYP_ART": "D04 ",
"TYP_ART": "D05 ",
"TYP_ART": "D06 ",
"TYP_ART": "D07 ",
"TYP_ART": "D08 ",
"TYP_ART": "D09 ",
"TYP_ART": "D10 ",
"TYP_ART": "D11 ",
"TYP_ART": "D12 ",
"TYP_ART": "D88 ",
"TYP_ART": "D99 ",
FidelioSPMSWSJsonPost
This function supports JSON post only. It does not support JSON get and JSONP get.
Table 3-2 FidelioSPMSWSJsonPost Input Parameters
psFunction |
String |
Function to call. |
Yes |
psSessionID |
String |
Session ID. |
Yes |
psParam |
Array of String |
Optional |
Below are the descriptions of the parameters.
psFunction
psSessionID
When a function is called and if it returns the error below, you must reverify by performing another function call. If failed, then re-login and retry.
Expiry"
When you call a function and it returns the error below, you must change the password and retry.
first"
poParam
The field value depends on the fuunction called. Please refer to the function details for each available parameters.
Return Values
Return the following Class value. The variable bSuccess is used to determine if the function call is successful or fail. If fail, sErrMsg will be populated with the error message. All other fields will depend on the function call.
End ClassNote:
Sample JSON
The requirement is that you must pass in the Content-Type: application/json; charset=utf-8
POST /OHCWebServices/OHCWebServices.asmx/FidelioSPMSWSJsonPost HTTP/1.0
Host: localhost
Content-Length: 69
{psFunction:'WSFunction',psSessionID:'SessionID',psParam:['GetCabin','05002']}
Below is the sample response that return two tables and the text in red represent the second table.
"bSuccess":true,
"sErrMsg":"",
"CAB_ID": "05002 ",
"CAB_DECK": "D05 ",
"CAB_DESIGN": "P",
"CAB_TYPE": "CD4 ",
"Table2": [
"TYP_ART": "D00 ",
"TYP_ART": "D02 ",
"TYP_ART": "D03 ",
"TYP_ART": "D04 ",
"TYP_ART": "D05 ",
"TYP_ART": "D06 ",
"TYP_ART": "D07 ",
"TYP_ART": "D08 ",
"TYP_ART": "D09 ",
"TYP_ART": "D10 ",
"TYP_ART": "D11 ",
"TYP_ART": "D12 ",
"TYP_ART": "D88 ",
"TYP_ART": "D99 ",
FidelioSPMSWSXML
This function only supports Simple Object Access Protocol (SOAP).
Table 3-3 FidelioSPMSWSXML Input Parameters
psFunction |
String |
Function to call. |
Yes |
psSessionID |
String |
Session ID. |
Yes |
poParam |
Array of Object |
Optional |
psFunction
psSessionID
When a function is called and if it returns the error below, you must reverify by performing another function call. If it fails, then re-login and retry.
Expiry"
When you call a function, and it returns the error below, you must change the password and retry.
first"
Please make sure you change the app.config in order for this to work.
<readerQuotas maxDepth="32" maxStringContentLength="100000"
maxArrayLength="16384"
poParam
The field value depends on the function called. Please refer to the function details for each available parameters.
Return Values
Return the below Class value. The variable bSuccess is used to determine if the function call is successful or fails. If fail, sErrMsg will be populated with the error message. All other fields depend on the function call.
Public Class CResponseXml
Public oTables() As Data Table
Public oPassenger As CPassenger
Public oGuestInfo() As CiPos.iGuestInfo
Public oObj As Object
Public oPeopleCount As CFCSecurity.PeopleCount
Public oAdvanceLoyaltyDiscount As CiPos.CAdvanceLoyaltyDiscount
Public oCreditCard As COHCCreditCard
Public oTerminal As TerminalNotification
End ClassSample XML
For example,
Public goWS As New FidelioSPMSWS.FidelioSPMSWSSoapClient
Dim oResponse As FidelioSPMSWS.CResponseXml
oResponse = goWS.FidelioSPMSWSXML("WSFunction", _
"Session", _
New Object() {"GetCabin", _
"05002"})
