8 Auto Update Pre-Register RFID Card on Online Door Lock System
This function is only applicable to ships running OHC VisiOnline in Onlne mode, which allows the registration of board cards at QCIShore DB using the web services RegisterRFIDBoardCard function.
This function pushes the pre-registered RFID ID to the VisiOnline System automatically, requesting access to the door lock, or a call for an update of the RFID ID of the lock.
The following scenarios explains the process during the registration of the card.
Guest A Card is registered and the RES_QCI_RFID_ID
is updated with the RFID UID.
The record is updated to the Ship DB in RES_QCI_RFID_ID
field and inserted into the RFID table with RFID_ACTIVE
= 1
and RFID_AUTO_UPD = 1
, and then runs
WPF Security in Ship DB.
Scenario 1
Scan the card registered card for Guest A using OMNIKey 5321.
A record is created and added to PVF and send to VisiOnline with
PVF_CMD=ResPostCheckIn
CCE
command is send to Ving to check in the card.
Scenario 2
The RES_QCI_RFID_ID
is updated, but the record
is not created in the RFID table in Ship DB.
Scan the card to check in at Gangway.
The record is added to RFID and the
PVF
table
Scenario 3
The RES_QCI_RFID_ID
is not created in the RFID table in Ship DB, and the Guest status
is Onboard.
Scan the card at the Gangway and this guest is placed in shore side. The RFID record is inserted.
Scan the card again, and the guest shows as going onboard and checked in.
Once the record is checked in, the record is added to the PVF table, to be send to VisiOnline
The system inserts to
PVF
when theRES_STATUS
changes fromRE
toCC
Scenario 4
If the RES_BOARDCC
for the guest does not match
the registered card track 2 value,
Scan the card at the Gangway.
System shows the card as not recognized.
