Preface
This document provides instructions on how to install the Oracle Hospitality Cruise Shipboard Property Management System (SPMS).
Audience
This document is for technical personnel, programmers, installers, application specialist, and users of SPMS.
Customer Support
To contact Oracle Customer Support, access the Customer Support Portal at the following URL:
Product version and program/module name
Functional and technical description of the problem (include business impact)
Detailed step-by-step instructions to re-create
Exact error message received
Screenshots of each step you take
Documentation
Oracle Hospitality product documentation is available on the Oracle Help Center at http://docs.oracle.com/en/industries/hospitality/cruise.html.
Revision History
Table -1 Revision History
| Date | Description of Change |
September 2021 |
Initial publication. |
March 2022 |
Added a note to section SPMS Platform for High Availability (HA). |
May 2022 |
Added topic Working with Invalid SPMS Encryption Key. |
July 2022 |
Made minor grammatical changes. |
November 2022 |
Removed references to SPMS v19.1 |
January 2023 |
Added steps to SPMS .NET Web Server Installation Steps. |
July 2023 |
Updated the content for Cruise Property Management System section. Added topic Applying Cruise Property Management Patch 20.2.x Upgrade. |
December 2023 |
Updated new customer portal. Added notation to chapter Connecting to Different SPMS Database using Different TNS. |
