7 Label Setup
You can use a Customized label to further identify a transaction
or add comments to an entry.
Figure 7-1 Customizing Labels for Cashbook Pay-In & Pay-Out
Log in to the Administration module.
Select System Setup, Labels Setup from the Administration option.
At the All Labels Listing, select PAYINW Pay Invoice, change the Label’s Description field to your description, and click OK.
You can also customize the Pay-in, Additional Comment, Further Detail, and CSB Custom Field labels using the above same steps.
Figure 7-2 Labels Setup for Pay Invoice and Pay-In
