Preface
Papagena Format
Generic Credit Card Format
Ingenico Handling
Servebase Handling
Paypoint Handling
NCL DCC Handling
Audience
This document is intended for installers, programmers, technical support teams, product specialists and others who are responsible for setting up Oracle Hospitality Cruise Shipboard Property Management System (SPMS) version 20.3.
Customer Support
To contact Oracle Customer Support, access the Customer Support Portal at the following URL:
Product version and program/module name
Functional and technical description of the problem (include business impact)
Detailed step-by-step instructions to re-create
Exact error message received and any associated log files
Screen shots of each step you take
Documentation
Oracle Hospitality product documentation is available on the Oracle Help Center at http://docs.oracle.com/en/industries/hospitality/cruise.html.
Revision History
Table -1 Revision History
| Date | Description of Change |
September 2022 |
Initial publication. |
June 2023 |
Updated new customer portal. |
