6 Reports
From the Crew File Menu, select Reports.
In the Reports List section ,click the (+) to expand the container, and select the report to print.
Navigate to the Print tab, and select the available Selection/Criteria.
Select a Printer, Print Range and Copies to print from its respective section, and click Print.
To view a report before printing, repeat the above steps and navigate to Preview tab.
To export the report, repeat the above steps, and click Export.
Batch Reporting
You can print a set of departmental reports by batch, and these reports are predefined in Administration module, System Setup, Reports Batch Printing Setup.
Select Reports Batch Printing from the Reports options.
In the Batch Reports Printing window, select the batch number to print.
In the Printer selection section, select the Printer and click Run.
