1 System Parameters
This section describes the available parameters for the EBORDER UK module which is accessible in Administration module, System Setup, Parameter.
Table 1-1 PAR Group EBORDER UK
PAR Name | PAR Value | Description |
Default to FNU on blank UXP_A_FSTN or FIRST_NAME |
1 |
1 – If the First Name is null, it defaults 0 – Disable. The First Name field must not be empty. |
FIELDS TO STRIP |
Comma Separated XML Field Name(s). These field(s)
will be stripped of invalid characters according to parameter setting
“ for example, |
File Output Folder |
Allows output file to be saved to a user-defined folder.
For example, |
Foreign Voyage Type |
Specify the Foreign Voyage Type options to be displayed in eBorder UK. Use Comma Delimited for example, Foreign to UK, UK to Foreign |
Include VOYAGE_NUMBER During Submission |
Voyage Number: 1 - Time Stamp, 2 - Cruise external system identifier 0 – Null/ or <blank> |
Mandatory Birthdate Field |
1 |
1 – Enable the birthdate field as mandatory 0 – Disable birthdate field for guests/crew handling |
Mandatory Fields For <ARRIVE> |
Specify the mandatory XML field for For example, |
Mandatory Fields For <CARGO> |
Specify the mandatory XML field for for example, |
Mandatory Fields For <COMP_CERT> |
Specify the mandatory XML field for <COMP_CERT>. Use Comma Delimited values. for example, |
Mandatory Fields For <CONTACT> |
Mandatory Fields For <CREW> |
Mandatory Fields For <DEPART> |
Mandatory Fields For <ISSC> |
Mandatory Fields For <LAST_PORT> |
Mandatory Fields For <NEXT_PORT> |
Mandatory Fields For <NONCREW> |
Mandatory Fields For <NONCREW> 1 |
Mandatory Fields For <NOTICE_DETAILS> |
Mandatory Fields For <PREVIOUS_FOREIGN_PORT_LIST> |
Mandatory Fields For <REPORTING_PARTY> |
Mandatory Fields For <SFTYMGMT_CERT> |
Mandatory Fields For <VESSEL> |
Mandatory Fields For <VESSEL_LOC> |
Mandatory Fields For <VOYAGE> |
Mandatory First Name Field |
1 |
1 - First Name Mandatory for expected crew or passengers 0 – Not mandatory for First Name Only crew/passenger records that contain this information is included in ENOAD Manifest submission when expected crew/passenger is chosen during file creation. |
Mandatory Gender Field |
1 |
1 - Gender is mandatory for expected crew or passengers 0 – Not mandatory for gender Only crew/passenger records that contain this information is included in ENOAD Manifest submission when expected crew/passenger is chosen during file creation. |
Mandatory ID Field |
1 |
1 - Passport (or other form of identification) is mandatory for expected crew or passengers. 0 – Not mandatory for passport Only crew/passenger records that contain this information is included in ENOAD Manifest submission when expected crew/passenger is chosen during file creation. |
Mandatory Last Name Field |
1 |
1 - Last Name is mandatory for expected crew or passengers 0 – Not mandatory for last name Only crew/passenger records that contain this information is included in ENOAD Manifest submission when expected crew/passenger is chosen during file creation. |
Mandatory Nationality Field |
1 |
1 - Nationality is mandatory for expected crew or passengers 0 – Not mandatory for nationality Only crew/passenger records that contain this information is included in ENOAD Manifest submission when expected crew/passenger is chosen during file creation. |
Manifest Submission Tracker |
If specified, a Tracker File is created with matching XML
File Name; for example, |
STRIP INVAL CHAR |
Comma Separated ASCII Code(s) Specify the non-alphanumeric characters (in ASCII Code) that will be stripped from the passenger/crew records section in the ENOAD Manifest. Specify the fields to which this handling needs to be applied in FIELDS TO STRIP parameter. for example, 33,35,36,37,38,42,61,91,93,94,123,125 |
Source Column For Record Locator |
Specifies the Database Column Used for For example, |
UNSUBMITTED NONCREW FIELDS |
Comma Separated XML Field Name(s) Specify the XML elements that should have their value left empty even if the information exists. This should only be done for non-mandatory fields that are known to contain data not formatted to NVMC specifications. for example, |
eBorderUK Web Service SOAPAction |
Obtain from the relevant website the Web Service SOAP Action for the eBorderUK . |
eBorderUK Web Service SOAPHeader |
Obtain from the relevant website the Web Service SOAP Header for the eBorderUK. |
eBorderUK Web Service URL |
Obtain from the relevant website the Web Service URL for the eBorderUK. |
