5 Parameters
This section describes the Parameters available to the Mobile Mustering module, and is accessible from the Administration module under System Setup, Parameter.
Table 5-1 PAR_GROUP_MOBILE
| PAR Name | PAR Value | Description |
Allow Crew Card Login Bypass |
0 or 1 |
Allow login using crew card scanning as long as crew credential is valid in Mobile DB. |
Allow to check-in RE/RR person when onboard |
0 or 1 |
Allow to check-in reservation status that is ‘RE’/’RE’ when the person is onboard |
Check-In Status |
0,1 or 2 |
Different Handling for 0 - Onboard after check-in 1 - Ashore after check-in, must swiped card to be onboard 2 - Display option box |
Enable Mobile Data Sync |
0 or 1 |
0 – Disable 1 - Enable Mobile Data Sync to FCMobile DB |
FC Mobile Gangway Client Version |
E.g: 8.0.1 |
FC Mobile Gangway Client Version Major |
0 or 1 |
Mobile Gangway Major Version 0 - Minor Update 1 - Major Update |
FC Mobile Gangway update type |
1 |
Last Update Date/Time |
Example: 20130925122924 |
Last Sync Date and Time in ISO format |
Mobile DB Version |
E.g: 7.30.8xx |
Mobile DB Version |
Offline Timeout |
Example: 6 |
Number of hours allowed to use in offline mode before sync is required |
Open Login Enabled |
0 or 1 |
0 - Must use correct login details 1 - Allow Open Login/Blind Login |
Require mandatory fields |
0 or 1 |
0-Do not require mandatory field 1-Require mandatory field |
Refresh Interval |
60 |
Interval time before the next DB synchronization. The default value is 60 seconds. |
Use System Date |
0 or 1 |
0 - Use Device Date 1 - Use System Date |
Table 5-2 PAR_GROUP_GANGWAY
Allow not expected guest to Check-In |
0 or 1 |
0 - Do not allow not expected guest to Check-In 1 - Allow not expected guest to Check-In |
Not allow to check-in Guest if no photo found |
0 or 1 |
0 - Allow guest to check-in without a photo taken 1 - Do not allow guest to check-in if no photo found |
