4 Single Person View
You can perform a registration/un-registration of the passenger by swiping the board card through a card reader, or by manually registering them by tapping the REGISTER?/UNREGISTER? button. Registration of the passenger is only permissible to the muster station you are logged in. Otherwise, you must manually change to the right muster station before registering the passenger. However, the registration mode may defer, depending on the parameter setting - Mobile, Current General Assembly Handling Mode with below possibilities:
Register all unexpected persons to the current muster station.
Prompt and allow the commander to decide whether or not to register the unexpected person on current muster station. The correct muster station/ lifeboat will be shown in red.
Forbid registration of unexpected person on the current muster station. In this case, the commander should not register the unexpected person on current muster station/ lifeboat. The correct muster station/ lifeboat is shown in red.
Figure 4-1 Person’s Profile Pending Registration
Figure 4-2 Person’s Profile Screen- Registered Status
Table 4-1 Single Passenger View Field Description
Field Name | Description |
Name |
Profile name. |
Picture |
Profile picture. |
Cabin / Gender |
Passenger Cabin number and gender. |
Status |
Registration Status – Registered, Pending Registration. |
Pax Class |
The passenger classification linked to S = Senior, A = Adult, C = Child, I = Infant, J = Junior. |
Muster Station |
The Muster Station assigned. |
Date & Time |
The Date/Time of the registration. |
Passport |
Encrypted passport number of selected passenger . Linked
to |
Type |
The passenger type linked to |
DOB & Age |
Date of Birth and age of the selected profile. Linked to |
Emergency Function |
The Emergency function assigned to Crew. Linked to |
Special Need Code |
The Special Need code(s) assigned to the reservation. Linked
to |
