Preface
This guide explains Point-of-Sale (POS) Discounts, used in the Oracle Hospitality Cruise Shipboard Property Management System (SPMS). It uses the Advanced MICROS Interface to handle the loyalty discount program.
A discount is applied automatically when the discount level is set up. The guest check displays the net payable amount when a discount is applied at the MICROS outlet.
Audience
This document is intended for application specialists and users of Oracle Hospitality Cruise Shipboard Property Management System.
Customer Support
To contact Oracle Customer Support, access the Customer Support Portal at the following URL:
Product version and program/module name
Functional and technical description of the problem (include business impact)
Detailed step-by-step instructions to re-create
Exact error message received and any associated log files
Screen shots of each step you take
Documentation
Oracle Hospitality product documentation is available on the Oracle Help Center at http://docs.oracle.com/en/industries/hospitality/cruise.html.
Revision History
Table -1 Revision History
| Date | Description of Change |
September 2022 |
Initial publication. |
June 2023 |
Updated new customer portal. |
