Preface
The Quick Check-In Synchronization (QCI Sync) is an interface that connects the Quick Check-In stations to the Shore-side database server through a separate network, enabling users to continue to work in an off-line mode.
Audience
This document is intended for project managers, application specialists and users of Oracle Hospitality Cruise Shipboard Property Management System.
Customer Support
To contact Oracle Customer Support, access the Customer Support Portal at the following URL:
Product version and program/module name
Functional and technical description of the problem (include business impact)
Detailed step-by-step instructions to re-create
Exact error message received
Screenshots of each step you take
Documentation
Oracle Hospitality product documentation is available on the Oracle Help Center at http://docs.oracle.com/en/industries/hospitality/.
Revision History
Table -1 Revision History
| Date | Description of Change |
September 2021 |
Initial publication. |
March 2022 |
Made minor grammatical changes. |
June 2023 |
Updated new customer portal. |
