6 Parameters
This section describes the Parameters available to the Safety Drill module, and they are accessible from System Setup, Parameters, Administration.
Table 6-1 PAR_Group: Safety
PAR Name | PAR Value | Description |
Advance Safety Drill |
0 or 1 |
0 - Standard Safety Drill Handling. 1 - Advance Safety Drill Handling. |
Course Code for Boat Commander |
XXX |
Qualifying course for Boat Commander. (XXX=COU_CODE) |
Allow Multiple Safety Number Assignment |
0 or 1 |
0 - Do Not Allow Multiple Safety Number Assignment. 1 - Allow |
Allow to use special In Port Manning handling |
0 or 1 |
0 - Disallow 1 - Allow |
Auto Set Ashore Denial During Drill Scheduling |
Specifies the duration before a Drill starts that going ashore is denied. Duration in minutes. |
Display Valid Courses On Muster List Assignment |
Displays the list of important courses on the Muster List Assignment window. PAR_VALUE should contain COU_CODE separated by commas. For example: 331,321. |
Operational Position that Receive Message |
The crew of certain operational position to receive a warning message in Active Muster List when there is expected crew in the muster list. |
Table 6-2 PAR_Group: Promo
SMTP Server IP Address |
Enter the Local Exchange server IP Address |
SMTP Server IP Address. |
SMTP Server IP Port |
Default SMTP IP Port is 25. |
SMTP Server Require Login Authentication |
0 – No or 1 - Yes |
SMTP Server Require Login Authentication. |
SMTP User Name |
<userName> |
Only valid when SMTP Server Requires Login Authentication is = 1. |
SMTP User Password (Encrypted) |
<userPassword> |
SMTP User Password. |
Sender Name |
<senderName> |
Sender Name. |
Sender Email |
<emailAddress> |
Sender Email. |
