Preface
This document provides instructions on how to install the Oracle Hospitality Cruise Shipboard Property Management System (SPMS).
Audience
This document is for technical personnel, programmers, installers, application specialist, and users of SPMS.
Customer Support
To contact Oracle Customer Support, access the Customer Support Portal at the following URL:
Product version and program/module name
Functional and technical description of the problem (include business impact)
Detailed step-by-step instructions to re-create
Exact error message received
Screenshots of each step you take
Documentation
Oracle Hospitality product documentation is available on the Oracle Help Center at http://docs.oracle.com/en/industries/hospitality/cruise.html.
Revision History
Table -1 Revision History
| Date | Description of Change |
September 2022 |
Initial publication. |
November 2022 |
Added minimum API and Apps Server specification Removed references to v19.1 |
March 2023 |
Revised Java JDK version from 11.0.7 to 17.0.4 Minor revision to chapter Installing SPMS Rest API/Web Application Server. Replaced topic Generating a new Key Pair using Java Keytool and Open SSL with Generating a new Key Pair using JSON Web Key generator Updated OAuth Public/Private Key file extension and removed the default password Updated Passport Scanner settings field descriptions |
June 2023 |
Updated new customer portal. |
July 2023 |
Updated the content for Cruise Property Management System section Added topic Applying Cruise Property Management Patch 20.3.x Upgrade |
November 2023 |
Added Uninstalling Cruise Property Management 20.3.3 Added notation to chapter Connecting to Different SPMS Database using Different TNS |
