22 SMTP Setup
The SMTP Setup allows you to set the email server settings to support sending of outgoing email in SPMS
System Parameters
The parameters that stores the SMTP Setup Settings are listed under parameter group “Promo”
Table 22-1 SMTP Parameters
PAR Group PAR Name PAR Value Description
Promo
SMTP Server IP Address
e.g. Webmail.xxx.com
The SMTP server name or IP address
Promo
SMTP Server IP Port
e.g. 25
The SMTP server port
Promo
SMTP Server Require Login Authentication
0 : No
1 : Yes
Setting to determine if login is required before SMTP server can send out email.
Promo
SMTP User Name
e.g. user123
Only valid if login required.
SMTP User Password
The SMTP User Password is configured in OHC Tools. You may refer to the section “Change Password” of OHC Tools user guide.
TLS 1.2 Setting for Windows
The SMTP Server on Windows are required to support secure connection. Minimally, TLS 1.2 is required. To configure TLS 1.2 on Windows, see Knowledge Article DOC11966 for more information.
