1 System Parameters
This section describes the available Parameters for the ENOAD module and they are accessible in Administration module, System Setup, Parameter.
Table 1-1 PAR Group ENOAD
PAR Name PAR Value Description
PAR Name
PAR Value
Description
Allow Blank Date
1
1 – Enable to allow blank date for expected guests/crew handling
0 – Disable
Allow Reuse of Departure-Notice-ID During Arrival
1
1 – Enable to allow reuse of departure-notice-ID during arrival
0 - If Set To FALSE, Use INITIAL Notification When Returning To Port
CARICOM Countries
<Country Name>
Specify the <Country name> to be tag as CARICOM members.
These countries listed will have the country name populated in State element as required for CARICOM submissions to NVMC.
For example, <BAHAMAS><BELIZE><ANTIGUA AND BARBUDA><BARBADOS><DOMINICA><GRENADA><GUYANA><HAITI><JAMAICA><MONTSERRAT><SAINT KITTS AND NEVIS><SAINT LUCIA><SAINT VINCENT AND THE GRENADINES><SURINAME><TRINIDAD AND TOBAGO>
Default to FNU on Blank UXP_A_FSTN or FIRST_NAME
1
1 – Enable. If the guest first name is null, it defaults the First Name field as “FNU”
0 – Disable. If disabled, the First Name field cannot be null
ENOAD Web Service SOAPAction
Obtain from NVMC website the relevant NVMC Web Service SOAP Action for the ENOAD System.
ENOAD Web Service SOAPHeader
Obtain from NVMC website the NVMC Web Service SOAP Header for the ENOAD System.
ENOAD Web Service URL
Obtain from NVMC website the NVMC Web Service URL for the ENOAD System.
FIELD TO STRIP
<element>
Comma Separated XML Field Name(s)
These field(s) will be stripped of invalid characters according to Parameter setting “STRIP INVAL CHAR”
For example, LAST_NAME,FIRST_NAME,ID_NUM,US_ADDRESS_STREET,US_ADDRESS_CITY,US_ADDRESS_STATE,US_ADDRESS_STATE_ABBR,US_ADDRESS_ZIP
File Output Folder
<path>
Allows output file to be saved to a user-defined local or network path folder. For example, C:\temp\apis\ENOAD
Foreign Voyage Type
<value>
Specify the Foreign Voyage Type options to be displayed in OHC ENOAD from the Voyage Type drop-down. Uses Comma Delimited values.
These values must not be edited unless advised to do so by Oracle Cruise Support as the changes may cause the ENOAD manifest submissions to fail.
For example, Foreign To US,Foreign To CARICOM,US To CARICOM,US To Foreign,CARICOM To Foreign,CARICOM To US,Foreign To Saint Lawrence Seaway,Saint Lawrence Seaway To Foreign
Include VOYAGE_NUMBER During submission
Voyage Number:
1 - Time Stamp,
2 - Cruise external system identifier
0 – NULL/ or <blank>
Mandatory Birthdate Field
1
1 – Enable the birthdate field as mandatory
0 – Disable birthdate field for guests/crew handling
Mandatory Field For <ARRIVE>
<element>
Specify the mandatory XML fields for <ARRIVE> element that ENOAD program will check during file creation. Use Comma Delimited Values.
For example, ARRIVE_DT,ARRIVE_TIME,PORT_NAME,CITY,STATE,FACILITY,PLACE
Mandatory Fields For <CARGO>
<element>
Specify the mandatory XML fields for <CARGO> element that ENOAD program checks during file creation. Use Comma Delimited Values.
For example,
GENERAL_DESC,CDC_ON_BOARD
Mandatory Fields For <COMP_CERT>
<element>
Specify the mandatory XML fields for <COMP_CERT> element that ENOAD program will check during file creation. Use Comma Delimited Values.
For example, ISSUED_DT,EXPIRATION_DT,AGENCY
Mandatory Fields For <CONTACT>
<element>
Specify the mandatory XML fields for <CONTACT> element that ENOAD program will check for during file creation. Use Comma Delimited Values.
For example, NAME,PHONE
Mandatory Fields For <CREW>
<element>
Specify the mandatory XML fields for <CREW> element that ENOAD program checks during file creation. Use Comma Delimited Values.
For example, POSITION,LAST_NAME,FIRST_NAME,BIRTH_DT,GENDER,NATIONALITY,NATIONALITY_CODE,COUNTRY_RESIDENCE,COUNTRY_RESIDENCE_CODE,ID_TYPE,ID_NUM,ID_COUNTRY,ID_COUNTRY_CODE,EMBARK_COUNTRY,EMBARK_COUNTRY_CODE,EMBARK_STATE,EMBARK_PORT_NAME,EMBARK_PORT_CODE,EMBARK_DATE
Mandatory Fields For <DEPART>
<element>
Specify the mandatory XML fields for <DEPART> element that ENOAD program will check during file creation. Use Comma Delimited Values.
For example, DEPART_DT,DEPART_TIME,PORT_NAME,CITY,STATE,PLACE
Mandatory Fields For <ISSC>
<element>
Specify the mandatory XML fields for <ISSC> element that ENOAD program will check during file creation. Use Comma Delimited Values.
For example, ISSUED_DT,VSP_IMPLEMENTATION,ISSC_TYPE,INTERIM_ISSC,FLAG_ADMINISTRATION,FLAG_ADMINISTRATION_CODE,CSO_NAME,CSO_PHONE
Mandatory Fields For <LAST_PORT>
<element>
Specify the mandatory XML fields for <LAST_PORT> element that ENOAD program checks during file creation. Use Comma Delimited Values.
For example, ARRIVE_DT,DEPARTURE_DT,LAST_PORT_COUNTRY,LAST_PORT_COUNTRY_CODE,LAST_PORT_STATE,LAST_PORT_NAME,LAST_PORT_CODE,LAST_PORT_PLACE
Mandatory Fields For <NEXT_PORT>
<element>
Specify the mandatory XML fields for <NEXT_PORT> element that ENOAD program checks during file creation. Use Comma Delimited Values.
For example, ARRIVE_DT,ARRIVE_TIME,NEXT_PORT_COUNTRY,NEXT_PORT_COUNTRY_CODE,NEXT_PORT_STATE,NEXT_PORT_NAME,NEXT_PORT_CODE,NEXT_PORT_PLACE
Mandatory Fields For <NONCREW>
<element>
Specify the mandatory XML fields for <NONCREW> element that ENOAD program checks during file creation. Use Comma Delimited Values.
For example, LAST_NAME,FIRST_NAME,BIRTH_DT,GENDER,NATIONALITY,NATIONALITY_CODE,COUNTRY_RESIDENCE,COUNTRY_RESIDENCE_CODE,ID_TYPE,ID_NUM,ID_COUNTRY,ID_COUNTRY_CODE,ID_EXPIRATION_DT,US_ADDRESS_STREET,US_ADDRESS_CITY,US_ADDRESS_ZIP
Mandatory Fields For <NONCREW> 1
<element>
Specify the mandatory XML fields for <NONCREW>  element that ENOAD program checks during file creation. Use Comma Delimited Values. (Continued)
For example, EMBARK_COUNTRY,EMBARK_COUNTRY_CODE,EMBARK_STATE,EMBARK_PORT_NAME,EMBARK_PORT_CODE,EMBARK_DATE
Mandatory Fields For <NOTICE_DETAILS>
<element>
Specify the mandatory XML fields for <NOTICE_DETAILS> element that ENOAD program checks during file creation. Use Comma Delimited Values.
For example, CREATED_DATE_TIME,NOTICE_ID,NOTICE_TRANSACTION_TYPE,NOTICE_TYPE,VERSION
Mandatory Fields For <PREVIOUS_FOREIGN_PORT_LIST>
<element>
Specify the mandatory XML fields for <PREIVOUS_FOREIGN_PORT_LIST> element that ENOAD program checks during file creation. Use Comma Delimited Values.
For example, ARRIVAL_DT,DEPARTURE_DT,PREVIOUS_COUNTRY,PREVIOUS_COUNTRY_CODE,PREVIOUS_PORT_NAME,PREVIOUS_PORT_CODE,PREVIOUS_PLACE
Mandatory Fields For <REPORTING_PARTY>
<element>
Specify the mandatory XML fields for <REPORTING_PARTY> element that ENOAD program checks during file creation. Use Comma Delimited Values.
For example, NAME,EMAIL,COMPANY
Mandatory Fields For <SFTYMGMT_CERT>
<element>
Specify the mandatory XML fields for <SFTYMGMT_CERT> element that ENOAD program checks during file creation. Use Comma Delimited Values.
Mandatory Fields For <VESSEL>
<element>
Specify the mandatory XML fields for <VESSEL> element that ENOAD program checks during file creation. Use Comma Delimited Values.
For example, NAME,CALL_SIGN,ID_NUM,ID_TYPE,FLAG,FLAG_CODE,OWNER,OPERATOR,CLASS_SOCIETY,CHARTERER,OCE,OCE_DESC,NTVRP_NUMBER
Mandatory Fields For <VESSEL_LOC>
<element>
Specify the mandatory XML fields for <VESSEL_LOC> element that ENOAD program checks during file creation. Use Comma Delimited Values.
For example, LOCATION_DESC,LAT_DEG,LAT_MIN,LAT_SEC,N_S,LONG_DEG,LONG_MIN,LONG_SEC,E_W
Mandatory Fields For <VOYAGE>
<element>
Specify the mandatory XML fields for <VOYAGE> element that ENOAD program checks during file creation. Use Comma Delimited Values.
For example, VOYAGE_TYPE
Mandatory First Name Field
1
1 - First Name Mandatory for expected crew or passengers
0 – Not mandatory for First Name
Only crew/passenger records that contain this information is included in ENOAD Manifest submission when expected crew/passenger is chosen during file creation.
Mandatory Gender Field
1
1 - Gender is mandatory for expected crew or passengers
0 – Not mandatory for gender
Mandatory ID Field
1
1 - Passport (or other form of identification) is mandatory for expected crew or passengers.
0 – Not mandatory for passport
Mandatory Last Name Field
1
1 - Last Name is mandatory for expected crew or passengers
0 – Not mandatory for last name
Mandatory Nationality Field
1
1 - Nationality is mandatory for expected crew or passengers
0 – Not mandatory for nationality
Manifest Submission Tracker
<path>
If specified, a Tracker File is created with matching XML File Name; for example, C:\Temp\APIS\ENOAD. Else, the default path is C:\Users\Public\Documents\Oracle Hospitality Cruise\ENOAD
STRIP INVAL CHAR
<ASCII Code>
Comma Separated ASCII Code(s)
Specify the non-alphanumeric characters (in ASCII Code) that will be stripped from the passenger/crew records section in the ENOAD Manifest. Specify the fields to which this handling needs to be applied in FIELDS TO STRIP parameter.
For example, 33,35,36,37,38,42,61,91,93,94,123,125
Source Column For Record Locator
<value>
Specifies the Database Column Used for <PASSENGER_RECORD_LOCATOR>
For example, RES_ACC
UNSUBMITTED NONCREW FIELDS
<element>
Specify the XML elements that should have their value left empty even if the information exists. This should only be done for non-mandatory fields that are known to contain data not formatted to NVMC specifications.
For example, US_ADDRESS_STATE_ABBR
Gender Description List
<Gender_Desc>
To specify XML fields for <GENDER> element which ENOAD will check for upon file creation. Use <> Delimited Values.
For example,
<Male><Female><Other>
