Preface
The Housekeeping module is a program that manages the daily cleaning and maintenance of the passenger cabins, staterooms, and public areas on a cruise ship. Apart from managing the cleaning task, it also allows you to schedule future preventative maintenance.
Audience
This document is intended for Ship’s System Administrator and/or Application Specialists of Oracle Hospitality Cruise Shipboard Property Management System (SPMS).
Customer Support
To contact Oracle Customer Support, access the Customer Support Portal at the following URL:
https://iccp.custhelp.com
When contacting Customer Support, please provide the following:
  • Product version and program/module name
  • Functional and technical description of the problem (include business impact)
  • Detailed step-by-step instructions to re-create
  • Exact error message received
  • Screen shots of each step you take
Documentation
Oracle Hospitality product documentation is available on the Oracle Help Center at http://docs.oracle.com/en/industries/hospitality/cruise.html.
Revision History
Table -1 Revision History
Date Description of Change
October 2023
Initial publication.
