Preface
EONE is an interface that receives and helps process the Crew’s master data, scheduled embarkation information, address details, emergency contact details, crew effects list, immigration data, and check-in / check-out request from the JD Edwards EONE (JDE E1) system.
Audience
This document is intended for project managers, application specialists, system administrators and users of Oracle Hospitality Cruise Shipboard Property Management System. (SPMS)
Customer Support
To contact Oracle Customer Support, access the Customer Support Portal at the following URL:
Product version and program/module name
Functional and technical description of the problem (include business impact)
Detailed step-by-step instructions to re-create
Exact error message received
Screenshots of each step you take
Documentation
Oracle Hospitality product documentation is available on the Oracle Help Center at http://docs.oracle.com/en/industries/hospitality/.
Revision History
Table -1 Revision History
| Date | Description of Change |
October 2023 |
Initial publication. |
