Prerequisites
Before you begin using the Norwegian Fiscal Enhancements, you must install the Digital Certificate. If the digital certificate is not present, the system will not allow you to perform any postings or payments. To apply a digital certificate, see section Key Pair Management for Digital Signature.
To comply with the Norwegian Tax Authority requirements, you must disable the financial functions of the SMART iCrew.
Table -1 List of User Security to Disable
Security Reference No. | Description |
11106 |
Cabin change in iCrew |
11641 |
Add payment in iCrew |
11642 |
Add posting in iCrew |
11643 |
Print invoice in iCrew |
51011 |
Book shore excursion in iCrew |
