2 Dashboard
The Dashboard is the landing page of the application that provides a summary of key information in a tab view once the user logs in successfully, and each of the tabs has its own analytic tiles.
The Check-In tab consists of
Checked-In and Pending Guest counts
VIP Guests counts
Onboard Visitors counts
Figure 2-1 Check-In Dashboard
The Gateway Security tab consists of:
Total Guest and Crew counts
Total Onboard Guest, Crew and Visitors counts
Ashore Guests and Crew counts
Overnight Tour counts
Disembarking Guest counts
Disembarked Guest counts
Figure 2-2 Gateway Security Dashboard
Safety Mode value
Edit (based on your security rights - Role Manager, Mustering, Dashboard, Edit)
Safety Mode selection
Muster Station/Lifeboat selection (based on the safety mode selection)
Counts (for all profiles: Guests, Residents, Crews, and Visitors)
Total Onboard
Registered
Pending
Bar chart of Registered/Pending by Designated Muster Stations/Lifeboats
Bar chart of Registered/Pending by Ship Vertical Zones
The dashboard bar chart for Registered/Pending by Ship Vertical Zones and the column for Ship Vertical Zone in the View List - Registered and View List - Pending page are shown only when:-
The Muster Station selection value is ‘All’ in Emergency Passenger Drill mode and General Assembly mode.
The Boat Type selection value is ‘All’ and Lifeboat selection value is ‘All’ in Abandon Ship mode.
Figure 2-3 Mustering Dashboard
Change Safety Mode Value and Reset Safety Mode Count
On the dashboard page, select Edit.
An edit drawer opens from the right.
Safety mode selection
Reset <the selected safety mode> count to 0 checkbox
Change the safety mode selection.
Check the Reset <the selected safety mode> count to 0 checkbox.
Check the Apply button.
To close the edit drawer and return to the previous screen, select the Cancel button or “X” icon.
Figure 2-4 Mustering - Edit Drawer
On the Registered tile, select View List link.
The system navigates to the Register page.
On the Register page, a summary (total adults, minor, and special needs) and a list of registered profiles of the current safety mode and muster station/lifeboat is shown. The Registered count shown depends on the filters by Ship Vertical Zones, All, Adults, Minors, and Special Needs.
Filtering the Ship Vertical Zones and toggling the All, Adults, Minors, and Special Needs option will give you a different result view. However, if you select the Special Needs hyperlink of the profile, this opens the Special Needs drawer, listing the special needs assigned:
total special needs count
selected special needs
remarks
Figure 2-5 Mustering Dashboard Registered Page
View List - Pending
On the Pending tile, select View List link.
The system navigates to the Pending page.
On the pending page, a summary (total adults, minor, special needs, and unassigned count) and a list of pending profiles of the current safety mode and muster station/lifeboat is shown. The Pending registration count shown depends on the filters by Ship Vertical Zones, All, Adults, Minors, and Special Needs.
Filtering the Ship Vertical Zones and toggling the All, Adults, Minors, and Special Needs option will give you a different result view. However, if you select the Special Needs hyperlink of the profile, this opens the Special Needs drawer, listing the special needs assigned.
remarks
Figure 2-6 Mustering Dashboard Pending Page
