Prerequisites, Supported Systems, Oracle Database, and Compatibility
This section describes the minimum requirements for Quick Check In Synchronization application.
QCI Shore Database Server
Oracle Database Server Installation
OHC Web Service Installation
You may install the QCI Shore Database Server on the supported Oracle Linux OS. However, OHC Web Service is a SOAP Web Service that can only be installed on a Microsoft Windows OS. Under this circumstance, you can opt to install the OHC Web Service on the supported Microsoft Windows Desktop OS listed in our compatibility matrix.
Although the OHC Web Service can be installed on a Windows Desktop OS, Windows Server OS is the preferred if one can be provisioned.
OHC SPMS Version 23.1 Installation
Latest version of OHC Advanced Quick Check In
PC running QCI Sync Interface
Oracle Client Installation
Latest version of QCI Sync Interface
PC running OHC Advanced Quick Check In at Shore-Side
Supported Operating System and Oracle Database
See Compatibility Matrix at http://docs.oracle.com/en/industries/hospitality/.
