Preface
The Safety Drill module manages the Muster drills conducted by the crew of the ship before embarking on a voyage, familiarizing passengers with escape routes, and preparing passengers for safe evacuation in the event of an emergency.
Audience
This document is intended for project managers, application specialists and users of Oracle Hospitality Cruise Shipboard Property Management System (SPMS).
Customer Support
To contact Oracle Customer Support, access the Customer Support Portal at the following URL:
Product version and program/module name
Functional and technical description of the problem (include business impact)
Detailed step-by-step instructions to re-create
Exact error message received
Screenshots of each step you take
Documentation
Oracle Hospitality product documentation is available on the Oracle Help Center at http://docs.oracle.com/en/industries/hospitality/cruise.html.
Revision History
Table -1 Revision History
| Date | Description of Change |
October 2023 |
Initial publication. |
December 2023 |
Updated the Security Reference Number for the Drill Location Set Definition. |
