Preface
This document provides an explanation and description of each of the exposed functions in the Oracle Hospitality Cruise Shipboard Property Management System (SPMS) Web Service.
Audience
This document is intended for:
Third-party vendors who wish to integrate with SPMS.
This document should be used as a technical reference for external parties to develop applications which requires interfacing to SPMS.
Customer Support
To contact Oracle Customer Support, access the Customer Support Portal at the following URL:
Product version and program/module name
Functional and technical description of the problem (include business impact)
Detailed step-by-step instructions to re-create
Exact error message received
Screenshots of each step you take
Documentation
Oracle Hospitality product documentation is available on the Oracle Help Center at http://docs.oracle.com/en/industries/hospitality/cruise.html.
Revision History
Table -1 Revision History
| Version | Date | Description of Change |
23.1 |
October 2023 |
Initial publication. |
23.1 |
November 2023 |
Updated PostingTotal Class for parameter gsCallNoDialed to String Type. |
