Preface
This document provides instructions on how to install the Oracle Hospitality Cruise Shipboard Property Management System (SPMS).
Audience
This document is for technical personnel, programmers, installers, application specialist, and users of SPMS.
Customer Support
To contact Oracle Customer Support, access the Customer Support Portal at the following URL:
Product version and program/module name
Functional and technical description of the problem (include business impact)
Detailed step-by-step instructions to re-create
Exact error message received
Screenshots of each step you take
Documentation
Oracle Hospitality product documentation is available on the Oracle Help Center at http://docs.oracle.com/en/industries/hospitality/cruise.html.
Revision History
Table -1 Revision History
| Date | Description of Change |
October 2023 |
Initial publication. |
November 2023 |
Added notation to chapter Connecting to Different SPMS Database using Different TNS. Revised the installation/uninstallation steps Added topic Applying Oracle Hospitality Cruise Property Management Patch |
January 2024 |
Updated content for Installing SPMS Web Services and added topic Setting Up Load Balancer for SPMS OPI WebServices. |
March 2024 |
Revised steps in Setting Java Home environment variable |
June 2024 |
Added a note that user can replace the background picture of the Login Page. |
