5 Payment Services Directive Two (PSD2) Handling
The Payment Services Directive Two (PSD2) enforces payment services providers to implement a strong customer authentication, prohibiting Third-Party Payment Service Providers (TPP) from accessing any other data from the customer payment account beyond those explicitly authorized by the customer. Customers will have to agree on the access, use and processing of these data.
Configuring PSD2
  1. Log in to the OHC OPI Manager module.
  2. Select Configuration tab and go to the Parameter options
  3. At the parameter Payment Service Regulation, you must set the parameter value to PSD2, and the value is case sensitive.
    • PSD2: Uses PSD2 legislation for authentication processes.
    • Blank/ other value: Uses standard workflow without specifying the payment service regulation
      To use PSD2,
      • you must enable the parameter ‘Enable Online Initial Authorization
      • the Offline Token and Tokenize Existing Credit card tabs will be disabled.
  4. In the Configuration tab, Schema Mapping, click the ‘Get/ Update Schema From OPI’ to update the schema.
  5. Once the schema update completes, click CpAuthor, CpSettl, CancelRequest, and make sure the below fields are configured correctly per the below tables.
    Table 5-1 CpAuthor
    Field Name SPMS Field Name Condition Constant Value Enabled Mandatory Direction
    CardId
    CRD_TOKEN
    ANSWERSTAT = 'OK'
    True
    True
    In
    CreditcardNum
    CRD_NO
    ANSWERSTAT = 'OK'
    True
    True
    In
    ExpyDate
    CRD_EXP
    ANSWERSTAT = 'OK'
    True
    True
    In
    PaymentMethod
    CCA_PAYMENTMETHOD
    ANSWERSTAT = 'OK'
    True
    True
    In
    PaymentMethod
    CCA_PAYMENTMETHOD
    InitTrx:0|Cit:|Moto:0|Vcc:0
    True
    True
    Out
    Table 5-2 CpSettl
    PaymentMethod
    CCT_PAYMENTMETHOD
    ANSWERSTAT = 'OK'
    True
    True
    In
    PaymentMethod
    CCA_PAYMENTMETHOD
    True
    True
    Out
    Table 5-3 CancelRequest
    PaymentMethod
    CANCELREQUEST_PAYMENTMETHOD
    True
    True
    Out
    Table 5-4 CpPayOnly (Optional)
    PaymentMethod
    CCA_PAYMENTMETHOD
    True
    True
    In
OPI Daemon Tools
  1. Launch the OPIDaemon Tools and to make sure the Payment Service Regulation is set to PSD2.
    You need to set the same at the client(s) running the OPIDaemon services
  2. To complete the configuration and to be able to use the PSD2, you must
    1. restart the OPI Web Service and OPIDaemon services
    2. relaunch the OHC Launch Panel and other modules
