Overview of SPMS Components
To set up a full SPMS 23.2 environment, the following components are required:
  1. SPMS Database Server.
  2. SPMS .NET Secure Server.
  3. SPMS .NET Web Server.
  4. SPMS Desktop Application Clients.
  5. SPMS REST API Server.
  6. SPMS Web Application Server.
It is important that you know and understand that each of the components listed above is not restricted to one component per machine. Depending on your operation requirements and resource availability, you can select one of the following options:
  1. Install all the components in the same machine.
  2. Install each component separately in a different machine.
  3. Install the components using a combination of both option 1 and option 2.
Below are the minimum system requirements for each server type. We strongly recommend that you refer to the Cruise Compatibility Matrix at Oracle Help Center for the latest Operating System and Database version.
