Preface
This document provides instructions on how to install the Oracle Hospitality Cruise Shipboard Property Management System (SPMS).
Audience
This document is for technical personnel, programmers, installers, application specialist, and users of SPMS.
Customer Support
To contact Oracle Customer Support, access the Customer Support Portal at the following URL:
Product version and program/module name
Functional and technical description of the problem (include business impact)
Detailed step-by-step instructions to re-create
Exact error message received
Screenshots of each step you take
Documentation
Oracle Hospitality product documentation is available on the Oracle Help Center at http://docs.oracle.com/en/industries/hospitality/cruise.html.
Revision History
| Date | Description of Change |
October 2024 |
Initial publication. |
December 2024 |
Added new topic Upgrading Oracle Hospitality Cruise Property Management Updated background image location path |
April 2025 |
Removal of wildcard certificate usage from Property Management System |
May 2025 |
G12857-04 - No changes, republication for Search utility |
