What You Should Know
General Knowledge
  • Have an operational understanding of Personal Computers (PC).
  • Understand the basic network concepts.
Operating System
  • Have working knowledge of Microsoft Windows OS and its user interface (UI).
  • Have working experience with Microsoft Windows Administrative privilege.
  • Have working experience with Microsoft Windows Server OS, especially Windows Server 2016 or newer version of Windows Server OS.
Database Management System
  • Have working experience with the Relational Database Management System (RDBMS), particularly Oracle Database 19c.
SPMS Installation
  • You can only install SPMS to local drives. Installation of SPMS on a mapped network drive is not supported.
  • Before you perform any SPMS database upgrade or SPMS software installation, you must be logged on with Windows Administrative privileges.
SPMS Integration
  • Third-party software providers integrating with SPMS web services must change their application to support the new login method documented in the OHCWebServices Technical Specifications, available at the Oracle Help Center for Oracle Hospitality Cruise Shipboard Property Management System Release 23.2
  • The SPMS web services login method for SPMS 8.0, 20.X and 23.X are compatible, whereas the SPMS web service login for SPMS 7.30 is different from the rest.
