Where to Download
SPMS releases are available at:
For a Major/Minor release, the first upload is on OSDC. Patch and Hotfix releases are subsequently uploaded to MOS. See My Oracle Support Help for download instructions.
SPMS Installation File
The Initial Release of the SPMS Installation files are distributed in OSDC. Running the SPMS Installation files will install all libraries, dependencies, and the bare minimum required by SPMS applications. Installation does not give you access to all SPMS applications. You need to download and deploy the SPMS package files. Follow the instructions below to download the SPMS Client Installer from Oracle Software Delivery Cloud.
Log in to the Oracle Software Delivery Cloud. https://edelivery.oracle.com/osdc/faces/Home.jspx
Search for Oracle Hospitality Cruise Shipboard Property Management System. Follow the instructions stipulated on the page to download.
Figure 1-5 Sample Oracle Software Delivery Cloud Download Page
Locate the downloaded SPMS Installation package in your download folder.
SPMS Package File
The SPMS Package files distributed in the later Patch and Hotfix releases are uploaded to My Oracle Support (MOS). The SPMS Package file contains programs, libraries, web services, and scripts deployed by SPMS. You can download the SPMS Package from My Oracle Support (MOS) using the instructions below:
Log in to My Oracle Support.
Upon a successful login, you are redirected to the Dashboard page below:
Select the Patches & Updates tab. Search for Oracle Hospitality Cruise Shipboard Property Management System
Select the package version to download.
Click Search to obtain the patch lists.
Figure 1-6 SPMS Patch List
From the result list, select the patch to download.
The screen shot below shows the downloaded SPMS Package folder.
