System Codes
The Systems Codes is an area where you would configure majority of the guest related codes. These codes is use to manage the guest preferences, requests and statistic tracking. These system codes are entered from Administration, System Codes and the setup is similar for most of the codes, with the exception for those marked with an asterisk (*).
Table 9-13 System Codes Field Definition
Function Name Description
Action Codes
A follow up code for services.
Amenity Codes
Amenities provided to guest.
VIP Codes
Use in defining the type of VIP categories.
Session Codes
Defines the session use in Cashbook module.
Handicap Codes
Defines the type of disability/accessibility required by guest.
Nationality Groups *
Defines group of nationality for use in Shore Denied list.
Accounts Categories
Defines the category of accounts group
Document Types *
Defines the acceptable type of legal documents.
Guest Categories
Defines the classification of guest types.
Dining Times
Defines the available dining time slots.
General Reason Codes *
Defines the reason codes use in various modules, for example, cabin change reason, voiding a transaction, and so on.
Marital Status Codes
Defines the guest/crew marital status.
Payroll Pension Plan Type
Defines the available pension plan offered to crew.
Nationality Codes *
Defines the nationality codes in ISO codes.
Travel Insurance
Defines the Travel Insurance plan available.
Comment Types
Defines the type of comments received. For example, Service, pricing, food quality and others.
Comment Report Types
Defines the method comments were received.
Comment Departments Involved *
Defines the department involves in handling the comments.
Resolution Types
Defines the resolution codes use in Comment
Comment Category
Defines the comment by category/group.
Chips Workstation
Defines the Chips & Pin workstation name.
Enable/Disable Log Entry
Defines the functions to enable/disable in the log entry, besides the default value.
eOne Enable Contingency Mode Reason Code
Defines the reason use when enabling contingency mode.
eOne Disable Contingency Mode Reason Code
Defines the reason use when disabling contingency mode.
Nationality Flag
Defines the additional Nationality Flag for Crew.
