Routing
The Routing function automates the transfer of charges within the crew account or to multiple accounts, allowing you to consolidate charges into one invoice/account. The use of this function is to facilitate the invoicing process at group reservations level or party/family traveling together. Depending on the requirements, the routing can be set up using one of these options: Pay for or Pay by.
Figure 7-36 Routing Tab
Table 7-16 Routing Tab Definition
| Section | Description |
1 |
Pays for - This section defines the payer account and whom the account is paying. |
2 |
For - This section defines where the assigned financial department is routed. |
3 |
Cabin number and name of crew payer is responsible. |
4 |
Financial Department code assigned. |
5 |
Button to set up or remove routing instructions. |
Before moving/routing the charges, be sure to first check the current routing arrangements to avoid duplication of routing, which may result on charges not being re-directed as planned.
