Show Duplicate
The system permits only one (1) Emergency Function per crew member, with the exception in the Scheduled Muster List where the same function assignment to an Expected Crew Member and Onboard Crew member is allowed. You can use this function to show all duplicate assignments and make corrections where necessary.
Depending on the selected tabs – Active or Scheduled and when you click the Show Duplicate, the system prompts a list of duplicate Emergency Function assignments. The Safety Officer is required to re-assigned the Emergency Function to a unique crew member, if any.
