Enabling Multi Thread Process
The DGS ResOnline Multi Thread Process is an enhanced feature that manages performance. Below are the setup steps.
Setting Up OHCSettings.Par
In addition to setting the parameters in DGS ResOnline application, additional parameters are added to further manage the performance process. You must manually insert these settings at the beginning of the OHCSettings.Par file.
Table 16-1 OHCSettings.Par
| Parameter | Description |
| [#Res Online Data Import.Parameter.LogLevel=3#] |
0: No logs. Does not log in into the database at application tier as well as database tier and nothing appears in UI. 1: Error on critical information only 2: Critical and important information - error and processing status only. 3: All information |
| [#Res Online Data Import.Parameter.ThreadCount=4#] |
| [#Res Online Data Import.Parameter.MemoryLimit=1000000#] |
| [#Res Online Data Import.Parameter.LogCommitCount=100#] |
Validating the Parameter Value
Based on the value defined in the above parameters, result returned by the system are shown in the following example:
ThreadCount = 4
Under the Action and Description column, records in process are shown in thread No 8, 9, 10 and 11 per the number of threads indicated.
Figure 16-4 Process Record Thread
Memory Limit
The DGS program is coded to restart with a 500MB memory, and when the default memory limit in the parameter is 1000000. The application restarts automatically when the memory reaches 1.5GB, or at value defined (500MB + limit defined). For example, if the defined memory limit is 500000, the application restarts when memory reaches 1.0GB.
The total memory used is also shown in the description column of the figure below:
Figure 16-5 Utilization Memory Limit
The system launches a Command Prompt window when the application restarts and closes the window after the application restart completes.
Figure 16-6 Program Restart Prompt
Process Log
In the Message tab, only the
runtime errors are shown. All other log entries are viewable from C:\Program Files (x86)\Oracle Hospitality Cruise\ResOnlineDataImport_yyyymmdd.txt.
