Pending Approval
Almost all the event data is imported from DGS ResOnline with pending approval status. To approve/decline these bookings, you must have access rights #4657 granted. The Pending Approval icon is disabled if you do not have the access rights #4657 login.
Request Comments
You can view the approved/declined requests comments by clicking the Comments icon at the ribbon bar.
Figure 3-16 Request Comments
Clicking the Status Filter at the menu bar allows you to filter all approval requests by status as described in the table below.
Table 3-5 Status Filter in Comments
| Status | Description |
All Open |
Lists all open status requests for location or item that is waiting for approval. |
Open Items |
Lists entire item request in open status that is waiting for approval |
Open Location |
List entire location request in open status that is waiting for approval. |
Declined |
Display list of declined location/item requests. |
Approved |
Display list of approved location/item requests. |
