Parameters
This section describes the Parameters available in the Housekeeping module. They, are accessible from the Administration module under System Setup, Parameter.
Table 12-7 PAR Group Safety
PAR Name PAR Value Description
Enable Ferry Operation
0 or 1
0 - Disable Ferry Specify Operation.
1 - Ferry Specify Operation.
Table 12-8 PAR Group General
Alter Cabin Status
0 or 1
0 - Disable cabin status changes for any updates of cabin clean status
1 - Enable cabin status changes for any updates of cabin clean status.
Note: This parameter must be enabled so that the cabin status is updated whenever someone checks in/out or is moved to another cabin. This is the pre requisite for tasks to be created in Housekeeping.
Table 12-9 PAR Group Housekeeping
Bypass Change of Cabin Clean State Upon Check-Out
0/1
0-Do not bypass, 1-Bypass
To control the change of cabin clean state upon guest check-out
Enable Auto Alert Message upon Guest Cabin Change
0/1
0-Disable auto alert, 1-Enable auto alert
To create an alert message for the housekeepers when a guest changes Cabin
Enable Auto Alert Message upon Guest Check-In
0/1
To create an alert message for the housekeepers when a guest checks-in
Housekeeping Positions
For example, 010
Stores all the OPO_ID for housekeeping crew
Minimum number of days onboard for Linen Change
For example, 8
Minimum number of stays onboard before a linen change is required for the cabin
Overnight Rush Cabin Before Midnight Hours
For example, 18
If par value is 6, then the system will consider cabins as rush cabins when it has guests checking-out 6 hours before midnight.
Overnight Rush Cabin Extended Hours
For example, 8
If par value is 8, then the system will cover rush cabins up until the 8th hour after midnight.
Validate Cabin Clean Status before Update
0/1
Do not allow to update to cabin clean status to VC/VD if cabin is occupied.
X day Before Check-Out To Skip Linen Change
For example, 3
X day to skip linen change just before the expected checkout date.
If checkout date is on 15th and par value=2, then skip any linen changes on 13th & 14th.
X day to Change Linen
For example, 4
X day to change linen after check-in. If check-in date is on the 1st and par value=3, then linen change is done on the 4th.
