Forgot Password
The Forgot Password is a password reset feature. This feature is only available in Launch Panel Login screen.
Setting up Password Reset
Log in to Administration module.
Select Database Parameter, Promo group and define the SMTP settings in the following parameters:
SMTP Server IP Address
SMTP Server IP Port
Sender Name
Sender Email Address
SMTP Require SSL. Depends on organization requirement
SMTP Server Require Login Authentication. If parameter enabled, define the following:
SMTP User Name
SMTP User Password
In the Launch Panel, select User Security. Define the Email address for the login user. See Figure 11-14.
Password Reset Feature
At the Launch Panel application window, click the Options button.
Figure 11-17 Launch Panel Forgot Password
Click the Forgot Password button. You must enter the user login ID and email address that matches the email defined in user login account.
Figure 11-18 Forgot Password Account Credential
Click the Send button. The system will prompt an “Invalid Email Address” message if the email address does not match. If the email matches, you will receive a temporary password and a notification message “An email with instruction how to reset your password has been sent EMAIL ADD” shall prompt.
The old password is no longer valid once a request for a password reset is triggered. Enter the temporary password at the Login window and click Login.
Figure 11-19 Sample Password Reset Notification Template
The system prompts you to change the password. Click OK and proceed to change the password.
