Parameters
This section describes the Parameters available to the Maintenance
module. They are accessible in the Administration module under System
Setup, Parameter. Changing these parameters alters the program behavior.
Consult Oracle Customer Support for further clarification if you are
unsure of the definition.
Table 13-2 PAR Group — Maintenance
| PAR Name | Description |
Allow Modify Work Order Date Time |
Enable modification of work order date/time. 0 = Do not allow 1 = Allowed to modify work order reported date time |
Default Tab for Work Overview |
Define the default tab to show. 0 = All 1 = Done 2 = Not Started 3 = In Progress |
Hide Work Order Request No |
Define Work Order Request No to be shown in Work Order Window. 0 = To show on window 1 = To hide from window |
Maximum picture size allow |
Specify the maximum picture size allowed |
Print By Task |
Enable Printing by Task. 0 = No print maintenance task 1 = Print |
