Digital Certificate Requirement
To implement digital signature cryptographic functions, a key pair of a private key and a public key is required. The key pair is stored in a digital certificate form. The Norwegian Tax Authority requires that the digital certificate format to be as shown below.
Format: x.509
Charset: UTF-8
Encoding: Base-64
Endianness: Little Endian
OAEP Padding: PKCS1 v1.5 padding
Private key size: 1024 bits
Hash Message Format: SHA-1
Digital Signature
Digital signature in our context here is the asymmetrically encrypted hash of the Transaction Data. Briefly, the digital signature is defined as:
<Transactiondatahash> = Sha-1(<Transactiondata>)
<Digitalsignature> = Rsa-1024(<Transactiondatahash >) Using The Private KeySigning and Verification Process
Figure 30-13 Signing and Verification Process
Figure 30-14 Sample Signed and Verified Certificate
Digital Signature Trail
To preserve the integrity of transactions, the Norwegian Tax Authority mandates that the digital signing process should be chained, as shown below where the signature trail that SPMS would apply appears for its digital signing function.
Cruise Line Company A
Ship AA
TransactionAA1
SignatureAA1
TransactionAA2
SignatureAA2 (from SignatureAA1)
TransactionAA3
SignatureAA3 (from SignatureAA2)
Ship AB
TransactionAB1
SignatureAB1
TransactionAB2
SignatureAB2 (from SignatureAB1)
TransactionAB3
SignatureAB3 (from SignatureAB2)
Cruise Line Company B
Ship BA
TransactionBA1
SignatureBA1
TransactionBA2
SignatureBA2 (from SignatureBA1)
TransactionBA3
SignatureBA3 (from SignatureBA2)
Ship BB
TransactionBB1
SignatureBB1
TransactionBB2
SignatureBB2 (from SignatureBB1)
TransactionBB3
SignatureBB3 (from SignatureBB2)
Verifying Digital Signature
Table 30-11 Digital Certificate Elements and Descriptions
| Element in SAF-T Cash Register | Description | Format and requirements | Examples |
signature (previous) |
Signature from previous receipt |
Base-64 If no previous receipt the signature value must be set to “0” – number zero |
signature_from_previous_receipt |
transDate |
Date at which the transaction was performed. |
YYYY-MM-DD Do NOT use time zone or combined date and time format. |
2014-01-24 2015-10-29 |
transTime |
Time at which the transaction was performed. |
hh:mm:ss Use ss=00 as default value if no information of seconds are available. Same as within the SAF-T export. Do NOT use time zone or combined date and time format. |
23:59:59 |
nr |
Transaction number. This must be a unique, sequential number within a journal. This will be the same as the number stated on the issued receipt |
No leading or ending spaces. |
123456789 |
transAmntIn |
The amount involved in the transaction, including VAT. |
Decimal Data Type: Numerical field with two decimals. Decimal separator “.” (dot). No thousand separators. No leading or ending spaces. |
1250.00 -1250.00 0.00 |
transAmntEx |
The amount involved in the transaction, excluding VAT. |
Decimal Data Type: |
1000.00 -1000.00 |
signature (current) |
Signature of current receipt |
Base-64 |
Get Transaction Data from e-journal xml file.
Ensure that you have the public key in PEM format. You need this to verify the signature.
Save the transaction data in message.txt file.
Save the signature in signature.txt file.
Go to Windows search and type “git bash” to start the command line tool.
Extract the public key from the certificate.
$ openssl x509 -pubkey -noout -in <certificate_name> > pubkey.pem -
Now, decode the base64 encoded signature and store it in
“<signature_name>.txt”file.$ cat signature.txt| base64 -d > <signature_name>.txt -
Finally, verify the signature.
$ openssl dgst -<name> -verify pubkey.pem -signature <signature_name>.txt message.txt
