OHC Payroll GL EOM
Apart from generating the payment file and submitting it to the bank, the application also enables you to submit the payroll payout for import into the General Ledger at the end of the month.
You must enable the parameter Payroll GL EOM listed in the following table. The configuration of the Pay code Maintenance, Contract Templates and usage of the crew payroll differs from the regular Payroll GL. The pay code must have:
GL Code
Validity Range – From / Until
Table 26-26 Payroll GL EOM Parameters
| Parameter Name | Description |
Date Format |
To determine the file date format to display in GL Payroll. The default date format is MM/DD/YY. |
Date Prefix |
Prefix to precede data value in the GL Payroll file. For ResidenSea, the prefix will be “PU-”. |
Mandatory Paid Thru Date for Vacation Pay |
The value “Y” identifies whether the Paid Thru date is mandatory when the Vacation Pay Pay code is assigned. The default value is “N”. |
Number of Day History Backup |
Number of days to keep the generated Payroll GL file in History folder. |
Pay code for Vacation Pay |
Designated Vacation Pay Pay-Code Type. (Pay code refers to TYP_SPG). Use comma (,) as delimiter if there is more than 1 Pay code Type. |
Transfer Folder |
This folder stores all generated Payroll GL files. |
