System Parameter
This section describes the parameters available to the QCI Sync module and is accessible through the Administration module, System Setup, Parameter, General group. You must configure these parameters before running the QCI Sync Interface.
Table 2-1 PAR Group General
PAR Name PAR Value Description
QCI Offline DB Terminate
24
Disallow the QCI Office DB to run if it is older than x hours. Specify in the parameter value. The default value is 24 hours.
QCI Offline DB Warning
12
Define when to prompt a warning message when the QCI Offline DB is older than x hour. The default value is 12 hours.
Pax BCard Track2 Length
16
The length of the 'BoardCC' coded on Track 2. The value must be > 15.
QCI Sync Active Warning
12
Prompt a warning message when the QCI Offline DB is running more than x hours. The default value is 12 hours.
