Reports
A set of standard report is loaded with the program during installation. If these reports are not suitable for ship operation, contact Oracle Customer Support for the report to be customized.
Printing a Report
From the View menu, select Reports.
At the Reports List section, click the (+) to expand the tree view, and select the report to print.
Navigate to the Print tab and select the available Selection/Criteria.
Select a Printer, Print Range and Copies to print from their respective section, and click Print.
To view a report before printing, repeat the above steps, and navigate to the Preview tab.
