Location Maintenance
A Spa Location is associated with a main revenue area within the Spa facilities. Usually a Spa is divided between Hair/Nail, Treatments and Fitness, but some ships may have additional locations, or some may only have one (1).
The Spa location is maintained in Location Maintenance from the main Setup menu.
Figure 5-4 Location Maintenance
Adding a New Location Maintenance
Right-click on the tree view, select Insert, complete the form and click the Insert.
Deleting a Location Maintenance
Select on the tree view, right-click and select Delete.
Table 5-9 Description of Available Options on Location Maintenance Setup
| Option | Description |
Code |
Short name for this location. |
Name |
Long name for this location. |
Opening |
The default opening time for this location in military time without a semicolon. |
Closing |
The normal time for this location in military time without a semicolon. If the location closes after midnight, the system accepts time beyond 2400 as closing time in the morning of the next day. |
Post Dept |
The “Departmental Prefix” – SDL for this location. This code prefixes itemizers to determine the Department ID to which a change is to be posted. This is a view name to store the SPA Department Prefix. The ‘Post Dept’ in the Location Maintenance Setup search for the setup in the Financial Setup – Spa Location Department Prefix, where the setup will store in Typ_SDL. For example: Spa Dept Prefix is 87, the item charges will post into the department where the POS Revenue Center = 87. |
Schedules |
The default number of schedules associated with this location. A schedule represents the calendar of appointments for a single therapist. |
MMS_ID |
MMS or external F&B system Department itemizer (Crunch time). |
Crew POS |
A list of Operational Positions that are assigned to work at this location. Clicking question mark (‘?’) button will open the list-box that lists all Crew Operational Positions. Check the boxes to select the Crew Position. |
Schedule/Caption Grid |
For each Schedule, enter the default caption for the Schedule. This caption appears on the booking calendar to help the crew member taking reservations find a suitable therapist for a service. |
