Copy System Account
The Copy System Account function copies the System Account from one database to another database.
In the Tools window, select Copy System Account from the ribbon bar.
In the Copy System account window, select the source database from the Server drop-down list and enter the User password.
At the end of the ribbon bar, click Connect under the Copy System Account group. The system accounts shall populate if the connection is successful.
Figure 14-8 Copy System Account
Check the Delete All Destination System Account to add or remove the account in the destination database. This is only possible when no posting exists in the account during the copy process.
Click Copy to complete the process.
