Setting Up Comment Departments
The Common Departments feature enable you to create and group various departments involved in handling a request or comment received.
Figure 9-38 Comment Departments Involved
This figure shows the set up window for Comment Departments Involved.
  1. Select the Comment Departments Involved from the System Codes menu.
  2. Right-click the blank space on the left panel and select Add New.
  3. Enter the Code, Description and the Comment.
  4. Click Apply to save.
