Scanning Device
The Cashbook module has a scanning function to store transaction documents. You must install a scanning device in Management module, Options, Hardware setup.
  1. Log in to Management module, select Options, and click the Document Scanner tab.
  2. Select the scanner from the Select Scanner drop-down list.
  3. Select the Set as Default checkbox to make the scanner you selected the default scanner.
  4. Select the Enable Manufacturer Default Settings Dialog before Scan checkbox to enable users to re-configure the scanning settings before the scanning process.
  5. At the Scanner Setting section, select the relevant options from the drop-down list.
  6. Select the Auto Brightness checkbox for the scanning effect and Deskew for straightening the image, and then adjust the brightness accordingly.
  7. Click OK to save the setting.
